Use the following procedure to remove specific IS-IS ports and MLT interfaces when you get the error IS-IS SPBM interfaces have been configured. Please delete these interfaces.
This procedure removes existing IS-IS ports and MLT interfaces. You can choose which port and MLT interfaces need to be removed. This command does not alter the other SPBM or IS-IS configurations.
You must enable SPBM before running the SPBM script.
enable
configure terminal
run spbm interface clean
If the script causes a configuration conflict or cannot execute a command, an error message displays and the script stops.
Run the spbm interface clean script:
Switch:1(config)# run spbm interface clean
***************************************************************** *** This script will guide you through deleting the *** *** IS-IS SPBM interfaces. *** *** --------------------------------------------------- *** *** The values in [] are the default values. *** *** If you wish to terminate or exit this script *** *** enter ^C <control-C> at any prompt. *** ****************************************************************** ISIS port interfaces to be deleted <a/b,c/d>[]:1/2,1/4,1/8 ISIS MLT interface <MLT ID LIST> []:1 IS-IS port 1/2 deleted IS-IS port 1/4 deleted IS-IS port 1/8 deleted ** 3 IS-IS port interfaces deleted ** MLT 1 deleted ** 1 IS-IS MLTs deleted **
